kcl-samples → coilover-assembly
coilover-assembly
// Coilover Assembly
// Consist of a lower and upper body combination with eye-end mounts at the top and bottom. 200 mm-long helical spring (44 mm OD, and wire diameter of 6 mm) captured between upper and lower seats; Internal piston rod running through the spring. Integrated bump-stop beneath the upper seat to limit compression stroke. The assembly provides adjustable ride height and damping when installed between chassis and wheel hub.
import "coilover-bottom.kcl" as coiloverBottom
import "spring.kcl" as coiloverSpring
import "coilover-top.kcl" as coiloverTop
// Place the Bottom Coilover Part
coiloverBottom
// Place the Coilover Spring
coiloverSpring
// Place the Top Coilover Part
coiloverTop
  |> translate(x = 0, y = 0.0, z = 200)
