Zoo got audited by Trail of Bits (again)
Secure code audits provide a unique view into the security of a product. While pentests have become a standard part of the security process for many companies, public secure code audits are still relatively uncommon. I believe one reason for that is that a lot of security processes evolve around checking the boxes and "Have you conducted a penetration test in 2025?" is a common question in security questionnaires.
In this blog post I want to highlight 2 findings from our recent 2026 audit, as well as our 2024 audit, performed by Trail of Bits. We'll dive deep on one vulnerability and demonstrate how one vulnerability could have been exploited.
View our 2024 audit report here and our 2026 audit report here .
Securing the Rust ecosystem
One goal of the audit was to evaluate the security of our authentication system which includes SAML and OIDC flows. We are using the samael library and sponsor its author for a few years with a monthly donation. Vasco Franco, one of the Trail of Bits auditors, found several issues in the validation of SAML responses. None of them were exploitable, but they showed that the current method of validation is not as robust as it could be.
The library takes the SAML response and verifies the signature using xmlsec, the most widely used library for XML signature verification. So far so good.
After that however it uses custom logic to find the nodes that have been verified. This might lead to inconsistencies between what xmlsec verified and what we consider verified.
Finally, the well-known serde library is used to deserialize the XML document into Rust structs, which adds another source of parsing differentials.
In summary, Vasco Franco showed that you can create states where the custom samael logic, xmlsec, or serde disagree on what has been verified, which could lead to exploitable states.
The goal of samael is to deserialize only signed data into Rust structs, dropping everything else. So we are reducing the SAML response which can contain unsigned data into its minimal signed form. The relevant code implements a function which takes a signed SAML response and returns structured Rust data which you can trust it originates from the SAML IdP.
Again, nothing was found to be exploitable but we can do better here so we created a Pull Request to fix the issues by proposing new modes for parsing the signed SAML document after signature verification:
  1. ValidateAndMark - Legacy mode which marks the xmlsec returned node, its ancestors and descendants as verified.
  2. ValidateAndMarkNoAncestors - Similar to the legacy mode but only mark the xmlsec returned node and root ancestor node as verified.
  3. PreDigest - New strict mode, which gets the XML data just before the digest is calculated. This XML data is guaranteed to contain only data that has been signed.
Now, which mode works for you likely depends on your IdP. We are hesitant to make the PreDigest mode default for all users of the library. Zoo is switching to the PreDigest mode as we know the IdPs which are currently supported and those work with PreDigest mode.
Based on the changes recommended by Trail of Bits, we created a patch that addresses the identified issues. The version 0.0.20 of samael contains the fixes.
Turning path traversal into RCE
In the 2026 audit, Dominik from Trail of Bits found a path traversal vulnerability in our handling of CAD files.
Our /file/conversion API endpoint allows users to upload 3D files in various formats (STEP, FBX, SLDPRT) for conversion. The endpoint accepts multipart file uploads where the filename is attached. We had implemented a normalize_path function to sanitize user-provided filenames and prevent path traversal attacks by removing .. and . components. However, the function had a subtle but serious flaw: it preserved absolute paths.
When a user uploads a file with a filename like /etc/cron.d/malicious, the normalize_path function would return it unchanged. The function correctly handled absolute paths.
The real problem emerged due to Rust's PathBuf::join semantics. When you call temp_dir.join("/etc/cron.d/malicious"), Rust replaces the base path entirely because the argument is absolute. So instead of creating a file at /tmp/input_abc123/etc/cron.d/malicious, the file gets written to /etc/cron.d/malicious.
This vulnerability could have been exploited in at least two ways:
  • Remote Code Execution: An attacker could upload an ELF binary or shared library to replace the running process or overwrite libraries loaded by the HOOPS SDK at runtime.
  • DNS Hijacking: Overwriting /etc/hosts or /etc/resolv.conf could redirect service-to-service traffic or DNS requests to attacker-controlled servers.
The exploitation was constrained by two factors. First, Cloudflare WAF blocks some obvious payloads targeting paths like /etc/cron.d/. Second, the attacker needed to find a writable path that would grant them meaningful capabilities. However, the underlying vulnerability remained exploitable if the WAF was bypassed or if the attacker targeted less obvious paths.
We resolved this vulnerability by fixing the path normalization logic. Some paths are also directly rejected by our backend now. Additionally, we are using now kernel-level sandboxing to restrict processes from reading and writing unexpected paths.
Internally, we turned this vulnerability into a full-blown exploit that allowed us to pop a shell on our containers. We used this to validate our fixes, and to demonstrate internally how an attacker could have exploited this vulnerability. On top of that we are reducing what an attacker could do if they got remote code execution. We are reducing the availability and lifetime of API credentials throughout the organization.
Highlights from the 2024 audit
In our 2024 review with Trail of Bits, we did not discover a full-blown remote code execution vulnerability. However, we had several denial-of-service vectors identified, as well as a chain of web related vulnerabilities that would have allowed an attacker to phish Zoo users. Such a phishing attack would have allowed an attacker to steal a users session cookie. Any risks related to these vulnerabilities were mitigated.
Beyond audits: Defense in depth
Source code audits can discover serious vulnerabilities. Doing them once is not enough though, they need to be performed regularly. Also, they are only one part of a comprehensive security program.
We have also seen impact in other areas over the past years. In April 2025, N008x reported through our responsible disclosure program that our Microsoft SSO integration was vulnerable to nOAuth. The bug allows an account takeover. The issue stemmed from trusting the email claim provided by Microsoft instead of using the immutable sub (subject) claim as the primary identifier.
An attacker could create their own Azure AD tenant, add a user with an arbitrary email address (like victim@example.com), and then sign in to Zoo using "Sign in with Microsoft" with those credentials. Because we trusted the email claim without verification, the attacker would gain access to the victim's account. We fixed this by switching to the sub claim as the primary identifier and implementing proper email verification before account linking.
We reviewed our logs and validated that the vulnerability was not exploited. We expired all user sessions and unlinked all Microsoft accounts as a precautionary measure. Now fast-forward to 2026, in the Trail of Bits audit one finding actually referenced this vulnerability and recommended to implement a mitigating feature that requires email validation for any account linking. We implemented this feature now. If any of our SSO providers ever has a similar mis-behavior like Microsoft did, we are prepared!
Learnings from the audits
Regular audits are crucial for maintaining security. I suspect that we will see patterns emerge from the audits over time. With every new service deployed it probably makes sense to revisit older audits, and check if we might be vulnerable to similar issues in new parts of our codebase. One way to reduce the risk is to write static analysis rules and seed LLMs with previous audits to find attack ideas and validate ideas.
Max Ammann
Max Ammann
