kcl-samples → socket-head-cap-screw
// Socket Head Cap Screw
// This is for a #10-24 screw that is 1.00 inches long. A socket head cap screw is a type of fastener that is widely used in a variety of applications requiring a high strength fastening solution. It is characterized by its cylindrical head and internal hexagonal drive, which allows for tightening with an Allen wrench or hex key.
// Define parameters
boltDiameter = 0.190
boltLength = 1.0
boltHeadLength = boltDiameter
boltHeadDiameter = 0.313
boltHexDrive = 5 / 32
boltHexFlatLength = boltHexDrive / (2 * cos(toRadians(30)))
// Create the head of the cap screw
boltHead = startSketchOn(XZ)
  |> circle(center = [0, 0], radius = boltHeadDiameter / 2, tag = $topEdge)
  |> extrude(length = -boltHeadLength)
  |> fillet(radius = 0.020, tags = [topEdge, getOppositeEdge(topEdge)])
// Define the sketch of the hex pattern on the screw head
hexPatternSketch = startSketchOn(boltHead, face = START)
  |> startProfileAt([
       boltHexDrive / 2,
       boltHexFlatLength / 2
  |> angledLine(angle = 270, length = boltHexFlatLength)
  |> angledLine(angle = 210, length = boltHexFlatLength)
  |> angledLine(angle = 150, length = boltHexFlatLength)
  |> angledLine(angle = 90, length = boltHexFlatLength)
  |> angledLine(angle = 30, length = boltHexFlatLength)
  |> extrude(length = -boltHeadLength * 0.75)
boltBody = startSketchOn(boltHead, face = END)
  |> circle(center = [0, 0], radius = boltDiameter / 2, tag = $filletEdge)
  |> extrude(length = boltLength)
  |> fillet(radius = .020, tags = [getOppositeEdge(filletEdge)])
  |> appearance(color = "#4dd043", metalness = 90, roughness = 90)
