kcl-samples → car-wheel-assembly
car-wheel-assembly
// Car Wheel Assembly
// A car wheel assembly with a rotor, tire, and lug nuts.
@settings(defaultLengthUnit = in, kclVersion = 1.0)
// Import parts
import "car-wheel.kcl" as carWheel
import "car-rotor.kcl" as carRotor
import "brake-caliper.kcl" as brakeCaliper
import "lug-nut.kcl" as lugNut
import "car-tire.kcl" as carTire
// Import parameters
import * from "parameters.kcl"
// Place the car rotor
carRotor
  |> translate(y = 0.055)
// Place the car wheel
carWheel
// Place the lug nuts
lugNut
  |> patternCircular3d(
       arcDegrees = 360,
       axis = [0, 1, 0],
       center = [0, 0, 0],
       instances = lugCount,
       rotateDuplicates = false,
// Place the brake caliper
brakeCaliper
// Place the car tire
carTire
