Makeathon00:00:00:00Registration open
Std Solid Subtract
subtractFunction in std::solid
Subtract removes tool solids from base solids, leaving the remaining material.
Performs a bool subtraction operation, removing the volume of one or more tool solids from one or more base solids. The result is a new solid representing the material that remains after all tool solids have been cut away. This function is essential for machining simulations, cavity creation, and complex multi-body part modeling.
solids[Solid; 1+]The solids to use as the base to subtract from.Yes
tools[Solid]The solids to subtract.Yes
legacyMethodboolYou probably shouldn't set this or care about this, it's for opting back into an older version of an engine algorithm. If true, revert to older engine SSI algorithm. Defaults to false.No
[Solid; 1+]
