Makeathon00:00:00:00Registration open
Std Solid Fillet
filletFunction in std::solid
Blend a transitional edge along a tagged path, smoothing the sharp edge.
Fillet is similar in function and use to a chamfer, except a chamfer will cut a sharp transition along an edge while fillet will smoothly blend the transition.
solidSolidThe solid whose edges should be fillettedYes
radiusnumber(Length)The radius of the filletYes
tags[Edge; 1+]The paths you want to filletYes
tagTagDeclCreate a new tag which refers to this filletNo
legacyMethodboolYou probably shouldn't set this or care about this, it's for opting back into an older version of an engine algorithm. If true, revert to older engine SSI algorithm. Defaults to false.No
