Std Solid Intersect
intersectFunction in std::solid
Intersect returns the shared volume between multiple solids, preserving only overlapping regions.
Intersect computes the geometric intersection of multiple solid bodies, returning a new solid representing the volume that is common to all input solids. This operation is useful for determining shared material regions, verifying fit, and analyzing overlapping geometries in assemblies.
solids[Solid; 2+]The solids to intersect.Yes
legacyMethodboolYou probably shouldn't set this or care about this, it's for opting back into an older version of an engine algorithm. If true, revert to older engine SSI algorithm. Defaults to false.No
[Solid; 1+]
