angledLine
angledLineFunction in std::sketch
Draw a line segment relative to the current origin using the polar measure of some angle and distance.
This is part of sketch v1 and is deprecated in favor of sketch-solve.
anglenumber(Angle)Which angle should the line be drawn at?Yes
lengthnumber(Length)Draw the line this distance along the given angle. Only one of length, lengthX, lengthY, endAbsoluteX, endAbsoluteY can be given.No
lengthXnumber(Length)Draw the line this distance along the X axis. Only one of length, lengthX, lengthY, endAbsoluteX, endAbsoluteY can be given.No
lengthYnumber(Length)Draw the line this distance along the Y axis. Only one of length, lengthX, lengthY, endAbsoluteX, endAbsoluteY can be given.No
endAbsoluteXnumber(Length)Draw the line along the given angle until it reaches this point along the X axis. Only one of length, lengthX, lengthY, endAbsoluteX, endAbsoluteY can be given.No
endAbsoluteYnumber(Length)Draw the line along the given angle until it reaches this point along the Y axis. Only one of length, lengthX, lengthY, endAbsoluteX, endAbsoluteY can be given.No
