Std Clone
cloneFunction in std
Clone a sketch or solid.
This works essentially like a copy-paste operation. It creates a perfect replica at that point in time that you can manipulate individually afterwards.
This doesn't really have much utility unless you need the equivalent of a double instance pattern with zero transformations.
Really only use this function if YOU ARE SURE you need it. In most cases you do not need clone and using a pattern with instance = 2 is more appropriate.
// Clone an array that includes an imported geometry, solid and sketch.
geometries[Sketch or Solid or ImportedGeometry; 1+]The sketch, solid, or imported geometry to be cloned.Yes
