Std Sketch Loft
loftFunction in std::sketch
Create a 3D surface or solid by interpolating between two or more sketches.
sketches[Sketch or [Segment; 1+]; 2+]Which sketches to loft (or segments, for surface lofts). Must include at least 2 sketches.Yes
vDegreenumber(_)Degree of the interpolation. Must be greater than zero. For example, use 2 for quadratic, or 3 for cubic interpolation in the V direction.No
bezApproximateRationalboolAttempt to approximate rational curves (such as arcs) using a bezier. This will remove banding around interpolations between arcs and non-arcs. It may produce errors in other scenarios. Over time, this field won't be necessary.No
baseCurveIndexnumber(_)This can be set to override the automatically determined topological base curve, which is usually the first section encountered.No
tagStartTagDeclA named tag for the face at the start of the loft, i.e. the original sketch.No
tagEndTagDeclA named tag for the face at the end of the loft.No
bodyTypestringWhat type of body to produce (solid or surface). Defaults to "solid".No
