Makeathon00:00:00:00Registration open
Std Solid Union
unionFunction in std::solid
Union two or more solids into a single solid.
solids[Solid; 2+]The solids to union.Yes
legacyMethodboolYou probably shouldn't set this or care about this, it's for opting back into an older version of an engine algorithm. If true, revert to older engine SSI algorithm. Defaults to false.No
[Solid; 1+]
