chamferFunction in std::solid
Cut a straight transitional edge along a tagged path.
Chamfer is similar in function and use to a fillet, except a fillet will blend the transition along an edge, rather than cut a sharp, straight transitional edge.
solid | Solid | The solid whose edges should be chamfered | Yes |
length | number(Length) | Chamfering cuts away two faces to create a third face. This is the length to chamfer away from each face. The larger this length to chamfer away, the larger the new face will be. | Yes |
tags | [Edge; 1+] | The paths you want to chamfer (legacy API) | No |
edges | [any] | Experimental. Experimental face API. Do not use in generated or user-facing KCL yet; prefer tags until point-and-click and migration support ships. Array of edge references; each element is an object with: - sideFaces: [Face | Tag; 1+] - Adjacent faces that share the edge(s) to chamfer - endFaces?: [Face |
secondLength | number(Length) | Chamfering cuts away two faces to create a third face. If this argument isn't given, the lengths chamfered away from both the first and second face are both given by length. If this argument is given, it determines how much is cut away from the second face. Incompatible with angle. | No |
angle | number(Angle) | Chamfering cuts away two faces to create a third face. This argument determines the angle between the two cut edges. Requires length, incompatible with secondLength. The valid range is 0deg < angle < 90deg. | No |
tag | TagDecl | Create a new tag which refers to this chamfer | No |
legacyMethod | bool | Deprecated as of KCL 2.0. You probably shouldn't set this or care about this, it's for opting back into an older version of an engine algorithm. If true, revert to older engine SSI algorithm. Defaults to false. | No |
version | number(_) | Experimental. What version of the fillet algorithm to use. Defaults to 1. 0 means "let the Zoo engine choose whichever version is best", 1 is the original Zoo fillet algorithm, 2 is the newer algorithm (supports rolling ball fillets). | No |
