startSketchOnFunction in std::sketch
Start a new 2-dimensional sketch on a specific plane or face.
This is part of sketch v1 and is soft deprecated in favor of sketch-solve.
Sketch on Face Behavior
There are some important behaviors to understand when sketching on a face:
The resulting sketch will include the face and thus Solid that was sketched on. So say you were to export the resulting Sketch / Solid from a sketch on a face, you would get both the artifact of the sketch on the face and the parent face / Solid itself.
This is important to understand because if you were to then sketch on the resulting Solid, it would again include the face and parent Solid that was sketched on. This could go on indefinitely.
The point is if you want to export the result of a sketch on a face, you only need to export the final Solid that was created from the sketch on the face, since it will include all the parent faces and Solids.
See sketch on face for more details.
Multiple Profiles
When creating multiple profiles in a sketch, each profile must be made separately and assigned to a variable. Using one pipeline to create multiple profiles, where one profile is piped into the next, is not currently supported.
Instead, use separate pipelines, and extrude an array of them all.
planeOrSolid | Solid or Plane | Profile whose start is being used. | Yes |
face | TaggedFace or Segment | Identify a face of a solid if a solid is specified as the input argument (planeOrSolid). Incompatible with normalToFace. | No |
normalToFace | TaggedFace or Segment | Identify a face of a solid if a solid is specified as the input argument. Starts a sketch on the plane orthogonal to this specified face. Incompatible with face, requires alignAxis. | No |
alignAxis | Axis2d | If sketching normal to face, this axis will be the new local x axis of the sketch plane. The selected face's normal will be the local y axis. Incompatible with face, requires normalToFace. | No |
normalOffset | number(Length) | Offset the sketch plane along its normal by the given amount. Incompatible with face, requires normalToFace. | No |
