Repeat a 3-dimensional solid, changing it each time.
patternTransform(
@solids: [Solid; 1+],
instances: number(_),
transform: fn(number(_)): { },
useOriginal?: bool,
): [Solid; 1+]
Replicates the 3D solid, applying a transformation function to each replica. Transformation function could alter rotation, scale, visibility, position, etc.
The patternTransform call itself takes a number for how many total instances of
the shape should be. For example, if you use a circle with patternTransform(instances = 4, transform = f)
then there will be 4 circles: the original, and 3 created by replicating the original and
calling the transform function on each.
The transform function takes a single parameter: an integer representing which
number replication the transform is for. E.g. the first replica to be transformed
will be passed the argument 1. This simplifies your math: the transform function can
rely on id 0 being the original instance passed into the patternTransform. See the examples.
The transform function returns a transform object. All properties of the object are optional, they each default to "no change". So the overall transform object defaults to "no change" too. Its properties are:
translate(3D point)Translates the replica, moving its position in space.
replicate(bool)If false, this ID will not actually copy the object. It'll be skipped.
scale(3D point)Stretches the object, multiplying its width in the given dimension by the point's component in that direction.
rotation(object, with the following properties)-
rotation.axis(a 3D point, defaults to the Z axis) -
rotation.angle -
rotation.origin(either "local" i.e. rotate around its own center, "global" i.e. rotate around the scene's center, or a 3D point, defaults to "local")
solids | [Solid; 1+] | The solid(s) to duplicate. | Yes |
instances | number(_) | The number of total instances. Must be greater than or equal to 1. This includes the original entity. For example, if instances is 2, there will be two copies -- the original, and one new copy. If instances is 1, this has no effect. | Yes |
transform | fn(number(_)): { } | How each replica should be transformed. The transform function takes a single parameter: an integer representing which number replication the transform is for. E.g. the first replica to be transformed will be passed the argument 1. This simplifies your math: the transform function can rely on id 0 being the original instance passed into the patternTransform. See the examples. | Yes |
useOriginal | bool | If the target was sketched on an extrusion, setting this will use the original sketch as the target, not the entire joined solid. | No |
[Solid; 1+]
// Each instance will be shifted along the X axis.
fn transform(@id) {
return { translate = [4 * id, 0, 0] }
// Sketch 4 cylinders.
sketch001 = startSketchOn(XZ)
|> circle(center = [0, 0], radius = 2)
|> extrude(length = 5)
|> patternTransform(instances = 4, transform = transform)
// Each instance will be shifted along the X axis,
// with a gap between the original (at x = 0) and the first replica
// (at x = 8). This is because `id` starts at 1.
fn transform(@id) {
return { translate = [4 * (1 + id), 0, 0] }
|> extrude(length = 5)
fn cube(length, center) {
l = length / 2
x = center[0]
y = center[1]
p0 = [-l + x, -l + y]
p1 = [-l + x, l + y]
p2 = [l + x, l + y]
p3 = [l + x, -l + y]
return startSketchOn(XY)
|> startProfile(at = p0)
|> line(endAbsolute = p1)
|> line(endAbsolute = p2)
|> line(endAbsolute = p3)
|> line(endAbsolute = p0)
|> extrude(length = length)
width = 20
fn transform(@i) {
return {
// Move down each time.
translate = [0, 0, -i * width],
// Make the cube longer, wider and flatter each time.
scale = [
pow(1.1, exp = i),
pow(1.1, exp = i),
pow(0.9, exp = i)
// Turn by 15 degrees each time.
rotation = { angle = 15deg * i, origin = "local" }
myCubes = cube(length = width, center = [100, 0])
|> patternTransform(instances = 25, transform = transform)
l = length / 2
x = center[0]
y = center[1]
p2 = [l + x, l + y]
width = 20
fn transform(@i) {
return {
rotation = {
angle = 90deg * i,
// Rotate around the overall scene's origin.
origin = "global"
myCubes = cube(length = width, center = [100, 100])
// Parameters
r = 50 // base radius
h = 10 // layer height
t = 0.005 // taper factor [0-1)
// Defines how to modify each layer of the vase.
// Each replica is shifted up the Z axis, and has a smoothly-varying radius
fn transform(@replicaId) {
scale = r * abs(1 - (t * replicaId)) * (5 + cos((replicaId / 8): number(rad)))
return {
translate = [0, 0, replicaId * 10],
scale = [scale, scale, 0]
// Each layer is just a pretty thin cylinder.
fn layer() {
// or some other plane idk
|> circle(center = [0, 0], radius = 1, tag = $tag1)
|> extrude(length = h)
// The vase is 100 layers tall.
// The 100 layers are replica of each other, with a slight transformation applied to each.
vase = layer()
|> patternTransform(instances = 100, transform = transform)
fn transform(@i) {
// Transform functions can return multiple transforms. They'll be applied in order.
return [
{ translate = [30 * i, 0, 0] },
{ rotation = { angle = 45deg * i } }
startSketchOn(XY)
|> startProfile(at = [0, 0])
|> polygon(
radius = 10,
numSides = 4,
center = [0, 0],
inscribed = false,
|> extrude(length = 4)
|> patternTransform(instances = 3, transform = transform)
n = 5
width = 10
gap = 1.5 * width
fn chessboard(@i) {
row = rem(i, divisor = n)
column = floor(i / n)
isEven = rem(i, divisor = 2) == 0
return [
translate = [row * gap, column * gap, 0],
replicate = isEven
startSketchOn(XY)
|> polygon(numSides = 4, radius = width, center = [0, 0])
|> extrude(length = 2)
|> rotate(yaw = 45)
|> patternTransform(instances = n * n, transform = chessboard)
