tangentialArcFunction in std::sketch
Starting at the current sketch's origin, draw a curved line segment along some part of an imaginary circle until it reaches the desired (x, y) coordinates.
This is part of sketch v1 and is deprecated in favor of sketch-solve.
When using radius and angle, draw a curved line segment along part of an imaginary circle. The arc is constructed such that the last line segment is placed tangent to the imaginary circle of the specified radius. The resulting arc is the segment of the imaginary circle from that tangent point for 'angle' degrees along the imaginary circle.
endAbsolute | Point2d | Which absolute point should this arc go to? Incompatible with end, radius, and offset. | No |
end | Point2d | How far away (along the X and Y axes) should this arc go? Incompatible with endAbsolute, radius, and offset. | No |
radius | number(Length) | Radius of the imaginary circle. angle must be given. Incompatible with end and endAbsolute and diameter. | No |
diameter | number(Length) | Diameter of the imaginary circle. angle must be given. Incompatible with end and endAbsolute and radius. | No |
angle | number(Angle) | Offset of the arc. radius must be given. Incompatible with end and endAbsolute. | No |
tag | TagDecl | Create a new tag which refers to this arc. | No |
