patternLinear2dFunction in std::sketch
Repeat a 2-dimensional sketch along some dimension, with a dynamic amount of distance between each repetition, some specified number of times.
sketches | [Sketch; 1+] | The sketch(es) to duplicate. | Yes |
instances | number(_) | The number of total instances. Must be greater than or equal to 1. This includes the original entity. For example, if instances is 2, there will be two copies -- the original, and one new copy. If instances is 1, this has no effect. | Yes |
distance | number(Length) | Distance between each repetition. Also known as 'spacing'. | Yes |
axis | Axis2d or Point2d | The axis of the pattern. A 2D vector. | Yes |
useOriginal | bool | If the target was sketched on an extrusion, setting this will use the original sketch as the target, not the entire joined solid. | No |
[Sketch; 1+]
