Std Sketch Close
closeFunction in std::sketch
Construct a line segment from the current origin back to the profile's origin, ensuring the resulting 2-dimensional sketch is not open-ended.
This is part of sketch v1 and is soft deprecated in favor of sketch-solve.
If you want to perform some 3-dimensional operation on a sketch, like extrude or sweep, you must close it first. close must be called even if the end point of the last segment is coincident with the sketch starting point.
sketchSketchThe sketch you want to close.Yes
