Extend a 2-dimensional sketch or individual segment of a sketch through a third dimension to create a new 3-dimensional volume or surface, or if extruded into an existing volume, cut into an existing solid.
You can provide more than one sketch to extrude, and they will all be extruded in the same direction.
When you sketch on a face of a solid, extruding extends or cuts into the
existing solid, meaning you don't need to union or subtract the volumes. You
can change this behavior by using the method parameter. See
sketch on face for more details.
sketches | [Sketch or Face or TaggedFace or TaggedEdge or Edge or Segment; 1+] | Which sketch or sketches should be extruded. | Yes |
length | number(Length) | How far to extrude the given sketches. Incompatible with to. | No |
to | Point3d or Axis3d or Plane or Edge or Face or Sketch or Solid or TaggedEdge or TaggedFace or any | Reference to extrude to. Incompatible with length and twistAngle. Not currently supported for extruding edges. Experimental face API: edge specifier objects ({ sideFaces = [faceTag1, faceTag2], endFaces? = [...], index? }) are not ready for generated or user-facing KCL yet; prefer existing point, axis, plane, edge, face, sketch, solid, or tag forms until point-and-click and migration support ships. | No |
symmetric | bool | If true, the extrusion will happen symmetrically around the sketch. Otherwise, the extrusion will happen on only one side of the sketch. | No |
direction | Point3d or Edge or TaggedEdge or Segment | Experimental. If specified, will extrude in this direction instead of the sketch plane normal. If an edge is being extruded, this defaults to halfway between the faces on either side of the edge. | No |
bidirectionalLength | number(Length) | If specified, will also extrude in the opposite direction to 'distance' to the specified distance. If 'symmetric' is true, this value is ignored. | No |
tagStart | TagDecl | A named tag for the face at the start of the extrusion, i.e. the original sketch. | No |
tagEnd | TagDecl | A named tag for the face at the end of the extrusion, i.e. the new face created by extruding the original sketch. | No |
draftAngle | number(Angle) | Experimental. Positive draft angle means the sketch gets smaller while extruding, i.e. inwards draft. Negative draft angle means the sketch gets bigger while extruding, i.e. outwards draft. Defaults to zero, i.e. no draft. | No |
twistAngle | number(Angle) | If given, the sketch will be twisted around this angle while being extruded. Incompatible with to. | No |
twistAngleStep | number(Angle) | The size of each intermediate angle as the sketch twists around. Must be between 4 and 90 degrees. Only used if twistAngle is given, defaults to 15 degrees. | No |
twistCenter | Point2d | The center around which the sketch will be twisted. Relative to the plane's origin. Only used if twistAngle is given, defaults to [0, 0] i.e. plane origin. | No |
method | string | The method used during extrusion, either NEW or MERGE. NEW creates a new object. MERGE merges the extruded objects together. The default is MERGE. | No |
hideSeams | bool | Whether or not to hide the seams between the original and resulting object. Only used if a face is extruded and method = MERGE | No |
bodyType | string | What type of body to produce (solid or surface). Defaults to "solid". | No |
[Solid; 1+]
