angledLineThatIntersectsFunction in std::sketch
Draw an angled line from the current origin, constructing a line segment such that the newly created line intersects the desired target line segment.
This is part of sketch v1 and is deprecated in favor of sketch-solve.
angle | number(Angle) | Which angle should the line be drawn at? | Yes |
intersectTag | TaggedEdge | The tag of the line to intersect with. | Yes |
offset | number(Length) | The offset from the intersecting line. | No |
tag | TagDecl | Create a new tag which refers to this line. | No |
