patternLinear3dFunction in std::solid
Repeat a 3-dimensional solid along a linear path, with a dynamic amount of distance between each repetition, some specified number of times.
solids | [Solid; 1+] | The solid(s) to duplicate. | Yes |
instances | number(_) | The number of total instances. Must be greater than or equal to 1. This includes the original entity. For example, if instances is 2, there will be two copies -- the original, and one new copy. If instances is 1, this has no effect. | Yes |
distance | number(Length) | Distance between each repetition. Also known as 'spacing'. | Yes |
axis | Axis3d or Point3d | The axis of the pattern. A 3D vector. | Yes |
useOriginal | bool | If the target was sketched on an extrusion, setting this will use the original sketch as the target, not the entire joined solid. | No |
[Solid; 1+]
