Std Transform Scale
scaleFunction in std::transform
Scale a solid or a sketch.
This is really useful for resizing parts. You can create a part and then scale it to the correct size.
For sketches, you can use this to scale a sketch and then loft it with another sketch.
By default the transform is applied in local sketch axis, therefore the origin will not move.
If you want to apply the transform in global space, set global to true. The origin of the model will move. If the model is not centered on origin and you scale globally it will look like the model moves and gets bigger at the same time. Say you have a square (1,1) - (1,2) - (2,2) - (2,1) and you scale by 2 globally it will become (2,2) - (2,4)...etc so the origin has moved from (1.5, 1.5) to (2,2).
objects[Solid; 1+] or [Sketch; 1+] or ImportedGeometryThe solid, sketch, or set of solids or sketches to scale.Yes
xnumber(_)The scale factor for the x axis.No
ynumber(_)The scale factor for the y axis.No
znumber(_)The scale factor for the z axis.No
globalboolIf true, the transform is applied in global space. The origin of the model will move. By default, the transform is applied in local sketch axis, therefore the origin will not move.No
factornumber(_)If given, scale the solid by this much. Equivalent to setting x, y and z all to this number. Incompatible with x, y or z.No
