Makeathon00:00:00:00Registration open
Std Sketch Sweep
sweepFunction in std::sketch
Create a 3D surface or solid by sweeping a sketch along a path.
This, like extrude, is able to create a 3-dimensional surface or solid from a 2-dimensional sketch. However, unlike extrude, this creates a body by using the extent of the sketch as its path. This is useful for creating more complex shapes that can't be created with a simple extrusion.
You can provide more than one sketch to sweep, and they will all be swept along the same path.
sketches[Sketch or Segment; 1+]The sketch or set of sketches that should be swept in space.Yes
pathSketch or Helix or [Segment; 1+]The path to sweep the sketch along.Yes
sectionalboolIf true, the sweep will be broken up into sub-sweeps (extrusions, revolves, sweeps) based on the trajectory path components.No
relativeTostringWhat is the sweep relative to? Can be either 'sketchPlane' or 'trajectoryCurve'.No
tagStartTagDeclA named tag for the face at the start of the sweep, i.e. the original sketch.No
tagEndTagDeclA named tag for the face at the end of the sweep.No
bodyTypestringWhat type of body to produce (solid or surface). Defaults to "solid".No
versionnumber(_)What version of the sweeping algorithm to use (leave unspecified or use 0 to use the default algorithm).No
[Solid; 1+]
