arcFunction in std::sketch
Draw a curved line segment along an imaginary circle.
This is part of sketch v1 and is deprecated in favor of sketch-solve.
The arc is constructed such that the current position of the sketch is placed along an imaginary circle of the specified radius, at angleStart degrees. The resulting arc is the segment of the imaginary circle from that origin point to angleEnd, radius away from the center of the imaginary circle.
Unless this makes a lot of sense and feels like what you're looking for to construct your shape, you're likely looking for tangentialArc.
angleStart | number(Angle) | Where along the circle should this arc start? | No |
angleEnd | number(Angle) | Where along the circle should this arc end? | No |
radius | number(Length) | How large should the circle be? Incompatible with diameter. | No |
diameter | number(Length) | How large should the circle be? Incompatible with radius. | No |
interiorAbsolute | Point2d | Any point between the arc's start and end? Requires endAbsolute. Incompatible with angleStart or angleEnd. | No |
endAbsolute | Point2d | Where should this arc end? Requires interiorAbsolute. Incompatible with angleStart or angleEnd. | No |
tag | TagDecl | Create a new tag which refers to this arc. | No |
