hyperbolic
hyperbolicFunction in std::sketch
Add a hyperbolic section to an existing sketch.
This is part of sketch v1 and is soft deprecated in favor of sketch-solve. The sketch-solve version of hyperbolic is still under development.
semiMajornumber(Length)The semi major value, a, of the hyperbolic equation x^2 / a ^ 2 - y^2 / b^2 = 1.Yes
semiMinornumber(Length)The semi minor value, b, of the hyperbolic equation x^2 / a ^ 2 - y^2 / b^2 = 1.Yes
interiorAbsolutePoint2dAny point between the segment's start and end. Requires endAbsolute. Incompatible with interior or end.No
endAbsolutePoint2dWhere should this segment end? Requires interiorAbsolute. Incompatible with interior or end.No
interiorPoint2dAny point between the segment's start and end. This point is relative to the start point. Requires end. Incompatible with interiorAbsolute or endAbsolute.No
endPoint2dWhere should this segment end? This point is relative to the start point. Requires interior. Incompatible with interiorAbsolute or endAbsolute.No
tagTagDeclCreate a new tag which refers to this arc.No
