elliptic
ellipticFunction in std::sketch
Add an elliptic section to an existing sketch.
This is part of sketch v1 and is soft deprecated in favor of sketch-solve. The sketch-solve version of elliptic is still under development.
centerPoint2dThe center of the ellipse.Yes
angleStartnumber(Angle)Where along the ellptic should this segment start?Yes
angleEndnumber(Angle)Where along the ellptic should this segment end?Yes
minorRadiusnumber(Length)The minor radius, b, of the elliptic equation x^2 / a^2 + y^2 / b^2 = 1.Yes
majorRadiusnumber(Length)The major radius, a, of the elliptic equation x^2 / a^2 + y^2 / b^2 = 1. Equivalent to majorAxis = [majorRadius, 0].No
majorAxisPoint2dThe major axis of the elliptic.No
tagTagDeclCreate a new tag which refers to this arc.No
