Std Gdt Concentricity
gdt::concentricityFunction in std::gdt
GD&T concentricity annotation specifying how closely a feature's median axis must align with datum references.
This is part of MBD.
Concentricity is a location tolerance for features of size. It controls the derived median points of the annotated feature relative to a datum axis. The tolerance zone is cylindrical, with a diameter equal to tolerance. Datum references are required.
In American Society of Mechanical Engineers (ASME) Y14.5, concentricity is applied regardless of feature size (RFS) and does not use maximum material condition (MMC) or least material condition (LMC) modifiers. ASME Y14.5-2018 removed concentricity in favor of other controls such as position or runout where appropriate. ISO standards use the name coaxiality for this concept.
tolerancenumber(Length)The diameter of the cylindrical tolerance zone.Yes
datums[string; 1+]The datum references to display in the feature control frame. Supports up to primary, secondary, and tertiary datums.Yes
edges[Edge or any; 1+]The edges to be annotated. Edge specifier objects ({ sideFaces = [...], endFaces? = [...], index? = 0 }) are experimental; do not use them in generated or user-facing KCL yet.No
Rendered example of gdt::concentricity 0
Rendered example of gdt::concentricity 1
