solver::coincident
solver::coincidentFunction in std::solver
Constrain points, or a point and a segment to be coincident.
Supports two points, or one point and one segment (line/arc). A single Point2d (e.g. [1mm, 2.5mm]) can be used to pin a point to a fixed position.
points[Segment or Point2d; 2+]Two or more sketch entities that should be coincident. When more than two inputs are provided, each item must be a point or ORIGIN.Yes
