solver::diameter
solver::diameterFunction in std::solver
Constrain the diameter of an arc or circle segment. Accepts a single arc or circle segment and constrains the distance from its center to its start point. Note: Diameter uses the same solver constraint as radius (distance between two points), but is stored as a separate constraint type for proper UI display.
pointsSegmentThe arc or circle segment whose diameter should match the value set with ==.Yes
labelPositionPoint2dOptional position for the displayed constraint label in the sketch's local 2D coordinate system.No
