Std Solid Blend
blendFunction in std::solid
Blend two surfaces together. Use bounded edges to control the extents of the newly created surface, or tagged edges to use the full edge span.
Or blend the full edges directly with tagged edges (no getBoundedEdge):
edges[BoundedEdge or TaggedEdge; 2]The two edges that will be blended. Tagged edges blend the full edge length.Yes
