regionFunction in std::sketch
Create a region from closed segments.
Form the region from sketch block segments that have a given point within a closed boundary. When using a 2D point, not a point from the sketch, the sketch parameter is required to specify which sketch the region is from.
Alternatively, form the region by tracing the first segment from its start point to the intersection with the second segment, and turn at each intersection using the direction until returning back to the first segment.
Important: Creating a region using the segments parameter is currently only supported when there is a single closed region in the sketch. If the sketch may have multiple regions, use the point parameter instead. Until this limitation is lifted, using a point to select a region is preferred.
To help allow the region's point to move with the sketch, which may be created parametrically, consider creating a construction point in the sketch and constraining it into place. Then you can refer to the point to create the region.
pointPoint2d or SegmentA point that is within the region's boundary.No
segments[Segment; 1+]The first two segments that form the region's boundary. In case of a circle, the one circle segment that forms the region. This parameter is currently only supported when there is only one region in the sketch. If the sketch may have multiple regions, use the point parameter instead.No
intersectionIndexnumber(_)Index of the intersection of the first segment with the second segment to use as the region's boundary. The default is -1, which uses the last intersection. This is only used when the segments argument is provided.No
directionstringCCW for counterclockwise, CW for clockwise. Default is CCW. This is only used when the segments argument is provided.No
sketchanyThe sketch that the region is from. This is required when point is a Point2d.No
