gdt::annotation
gdt::annotationFunction in std::gdt
GD&T annotation for attaching manufacturing text to faces or edges.
annotationstringThe annotation text to display.Yes
edges[Edge or any; 1+]The edges to be annotated. Edge specifier objects ({ sideFaces = [...], endFaces? = [...], index? = 0 }) are experimental; do not use them in generated or user-facing KCL yet.No
framePositionPoint2dThe position of the annotation relative to the leader arrow. The default is [100mm, 100mm].No
framePlanePlaneThe plane in which to display the annotation. The default is XY. Other standard planes like XZ and YZ can also be used. The annotation may be displayed in a plane parallel to the given plane.No
Rendered example of gdt::annotation 0
Rendered example of gdt::annotation 1
