gdt::distanceFunction in std::gdt
GD&T distance annotation for displaying measured edge lengths or distances between two entities.
tolerance | number(Length) | The acceptable distance tolerance. | Yes |
from | Face or TaggedFace or Edge or any | The face or edge to measure from. Must be used with to. The default position is the entity center. Edge specifier objects ({ sideFaces = [...], endFaces? = [...], index? = 0 }) are experimental; do not use them in generated or user-facing KCL yet. | No |
to | Face or TaggedFace or Edge or any | The face or edge to measure to. Must be used with from. The default position is the entity center. Edge specifier objects ({ sideFaces = [...], endFaces? = [...], index? = 0 }) are experimental; do not use them in generated or user-facing KCL yet. | No |
edges | [Edge or any; 1+] | The edges whose lengths are annotated. Cannot be combined with from or to. Edge specifier objects ({ sideFaces = [...], endFaces? = [...], index? = 0 }) are experimental; do not use them in generated or user-facing KCL yet. | No |
framePosition | Point2d | The position of the distance label relative to the measured geometry. The default is [100mm, 100mm]. | No |
framePlane | Plane | The plane in which to display the distance. The default is XY. Other standard planes like XZ and YZ can also be used. The distance may be displayed in a plane parallel to the given plane. | No |
leaderScale | number(_) | Scale of the distance arrows. The default is 1.0. Must be greater than 0. | No |
