hole::holeFunction in std::hole
From the hole's parts (bottom, middle, top), cut the hole into the given solid, at the given 2D position on the given face.
solid | Solid | Which solid to add a hole to. | Yes |
face | TaggedFace | Which face of the solid to add the hole to. Controls the orientation of the hole. | Yes |
holeBottom | Define bottom feature of the hole. E.g. drilled or flat. | Yes | |
holeBody | Define the main length of the hole. E.g. a blind distance. | Yes | |
holeType | Define the top feature of the hole. E.g. countersink, counterbore, simple. | Yes | |
cutAt | [number(Length); 2] | Where to place the cut on the given face of the solid. Given as absolute coordinates in the global scene. | Yes |
